RSVSR Guide to Black Ops 7 Weapon Prestige Rewards
Special place for International Passat clubs and our guests.
Standartinė Hartmann » 2026 Kov 10 09:39
BO7's weapon grind has a weird new twist: finishing a gun is basically the tutorial. The first time you see that "Prestige Available" prompt in the Gunsmith, it hits you that the real loop is about to start, whether you've been leveling in MP, Warzone, or Zombies. If you're the type who likes running the same rifle until it feels like an extension of your hands, this system finally rewards that obsession, and it's the sort of thing people chasing a CoD BO7 Bot Lobby will notice fast because every bit of weapon XP suddenly matters again.
What you give up when you prestige
Pressing the button isn't a free victory lap. Your weapon drops back to level 1 and, yeah, it stings. Most attachments lock again, so your comfy build gets gutted and you're back to running early-game setups that feel a little bare. The good news is the game doesn't mess with your style progress: camos, decals, stickers, reticles—those stay unlocked. So the choice is simple, but not easy: keep the tuned loadout you know works, or reset it for the long haul and accept you'll be rebuilding the same gun more than once.
Prestige 1 and 2 are the "quality of life" tiers
The first two prestiges are where the system tries to win you over. You re-hit the weapon's max level each time, but you start pulling rewards that actually change how the grind feels. Expect charms, some unique gear, and a few cosmetics that can carry over to other guns. The big deal is permanent attachment unlock tokens. Spend one on the optic you can't live without or the barrel that makes the recoil feel right, and you won't have to re-earn it after the next reset. It doesn't remove the grind, but it stops it from being a full restart every single time.
Weapon Prestige Master and the long haul
After that, you're into Master territory, and it's not pretending to be casual. The level cap stretches out to 250, and it's a commitment you'll feel over weeks, not hours. Milestones at 100, 150, and 200 drop mastery camos that are meant to turn heads in pre-game lobbies. Push to 250 and you land the animated "top shelf" camo, sometimes even usable across your wider loadouts, which is basically the whole point: proof you didn't just sample the gun—you lived on it.
Who this loop is really for
This system isn't aimed at players who bounce between ten weapons a night. It's for the ones who like mastery, routine, and small improvements—folks who don't mind running imperfect builds again because they're chasing that next milestone. If that's you, the resets start to feel less like punishment and more like a personal challenge, especially once you've banked a couple tokens and can keep your core attachments locked in; it's the same reason grinders and completionists still look up things like a BO7 Bot Lobby when they're trying to make the time investment feel a bit more controlled.RSVSR is where Black Ops 7 players come to keep the grind fun—real loadout advice, what's trending, and no-nonsense tips for Weapon Prestige. Hit max level, choose when to reset, keep your camos, and chase those Master rewards up to 250 without wasting time.
Hartmann
Pranešimai: 4
Užsiregistravo: 2026 Kov 10 09:01
Grįžti į WorldWide
